wizard of ahs
Has anyone seen what this is going to be ???
You can register using your Google, Facebook, or Twitter account, just click here.Gross vehicle weight rating (GVWR), or gross vehicle mass (GVM) is the maximum operating weight/mass of a vehicle as specified by the manufacturer including the vehicle's chassis, body, engine, engine fluids, fuel, accessories, driver, passengers and cargo but excluding that of any trailers.I'm sorry, what are you guys talking about?
Thanks,Look at the link in my signature below. Target vehicle weight is there, and I infer from statements there about target passenger accommodation that carrying capacity will be 400-450 lb. So about 1700 lb GVWR.
That may be what it "needs" to be, but EM is only counting on 2 at 220 lbs !!An 80% percentile man 50-59yrs is around 250lbs. So ideally it needs to be at least 275lbs. add 1250lbs, plus 50lb in the 'trunk' and you get 1850lbs.
If you use the 220lb stated above I get 1740lbs.
