Just a better place to have this discussion. Link back here if an EV quibble breaks out somewhere else. Then you'll have it all in one place.
It would be nice if this was more about how things could be rather than how they are not. We all know that EV for the masses isn't here yet, but could it? How would that play out? How CAN that play out?
There is a cross connect between fuel cells, hybrid drive and EV drive in that all use the technology of electric motor drive. All kinds of flexibility is encountered like detachable/swapable assemblies and all-wheel-drive. Hyrid drive and yes, range extended by ICE or by FC.
Things like flow-batteries and swap-out battery rentals are possible. Even vehicles with out power storage at all are possible with the advent of power rails or in road transmission.
It's a big subject, have at it!
Some terms ( s=specific, default )( g=general term )
ED=Electric Drive
EV = Electric Vehicle, Vehicle with ED
FC=Fuel Cell
ICE = internal combustion engine
EM=Electric motor
AWD = All Wheel drive
RWD=Rear wheel drive
FWD=Front Wheel drive (like the Elio)
DD = Direct Drive, no gears
single speed = 1 gear ratio only, includes DD
1F2R=one front wheel, two rear (trike, delta layout)
2F1R= ->like the Elio (reverse trike, tadpole layout)
AT=Automatic transmission
MT=Manual transmission
RPM = revolutions per second
MPG=miles per gallon
eMPG=ev miles per gallon, base on equivalent to current cost of fuels.
Motor=(g)a thing that converts energy into motion, for example EM or ICE
Engine=(s)an ICE
cg = center of gravity, measured in all three dimensions
cd = co-efficient of drag. used with frontal area to assess total aerodynamic drag
fa = frontal area, cross section of vehicle as seen from the front
hp = horse power, lifting 550 foot-pounds per second (745.7 watts)
example: lifting 275lbs for 2ft = lifting 550lbs for 1 ft = 1hp
w, watts = volts x amps
v, e, volts = amplitude of static energy level, use it like you would water pressure.
a, amps = volume of energy, consider it like the volume of water moved in 1 second
r, electrical resistance = consider it like the size of a water pipe
kw = 1000 watts
wh = w times hours
kwh = w times hours / 1000
hp = 1.2kw
motor power rating, continuous = * max hp an EM can sustain long term(maybe 15min+)
motor power rating, peak = * max hp an EM can sustain short term(maybe <1 sec)
Flow Battery = battery energy stored in a liquid that is pumped thru a reactor device
Autocycle = 2F1R or 1F2R, RWD or FWD or AWD, with full cabin, flat-bottom seats, seat-belts, steering wheel and the lighting same as 2F2R.
Autocycle-RT = Autocycle Reverse Trike, 2F1R
Autocycle-Trike = 1F2R
Motor-Trike (short version:Trike) = trike version of a motorcycle. Example:VW trikes or the Subaru X100.
RT = Reverse Trike (2F1R)
RT-Cabinscooter = Old term for a Autocycle-RT
'tadpole' = (adjective) reverse version of a trike
* either rating might be specified, peak could be as much as 5times continuous, so know which you are looking at, and the time length specified, and at what RPM. Generally added cooling will extend continuous but not peak.
I'll add useful terms here when encountered in the discussion.
ED=Electric Drive
FC=Fuel Cell
EM=Electric motor
Engine=(s)an ICE
kw = 1000 watts
wh = w times hours
hp = 1.2kw
