Trusting
It seems that when considering the idea of a larger trunk all the naysayers can only think of the small effect on the gas mileage. Consider this. You own an Elio and another car, and the other car gets about 20 mpg. Now consider your total combined gas expense for a year. Ok, every time you decide which car to use you have to consider if you need "hauling room" for the trip. Will the Elio carry all those groceries or can you get 2 suitcases in the Elio? If 20 percent of the time you ask yourself that question you are forced to use the "other car", you have consumed more combined gas per year with a "standard" Elio than you would have with the slightly reduced mileage of the enlarged trunk Elio. Or, to put it another way. Using your "big trunk" Elio 100 times a year at 80 mpg will save you more money than using your "standard" Elio 80 times a year at 84 mpg. "Usability" is a factor in calculating your fuel consumption. Pretty fancy thinkin for a dullar, huh?
