No Cruise On Eplus
Stephen Workman
I prefer a RUBBER floor (like what used to be standard in pickup truck floors) to ANY carpeting! MUCH easier cleanup and durability - not to mention sound deadening. I can put that in myself - thank you very much.
So happy to hear the cruise control is standard. I just hope it's a GOOD cruise control set up. I've driven with some that were wonderful, and other's that were ergonomically a disaster.
Don't know if it will be good or not, but definitely know it will be cheap!
Ray O
Canton, Ohio
For those who want or have cruise control. It is unsafe to use cruise control in slippery conditions. It has cause accident in the past. So if there is snow, ice or rain it is better to not use it. Another tip when there is glare in the road wear your sun glasses you will be supersized.
Oooh... Astroturf.... There's an idea. A sour apple green Elio with artificial grass carpeting on the inside.
How about pool table felt; you can pad the sides to act as cushions.
I'm going to go with Shag Carpeting on the floor, sides and headliner.
Not sure where I'm going to hang the matching fuzzy dice tho.
The long two tone orange stuff? Cool
Hang it off the little arm that holds the sunvisor. It will be off center, but it won't block your view.
Hang them with the squirrel tail on the radio antenna.
That would be a good trick; there is no external antenna, it's built into the roof skin.
