[QUOTE="has the info been released as to if just one or both of the front tires on an Elio will be powered so as to literally offer 1 wheel or 2 wheel drive ?/QUOTE]
I'm only an amateur engineer. But, logic will tell you that if you've cut your number of wheels to only three you'd better have the front two pulling at the same rate. That goes for breaking too. Paul has mentioned computer controlled antilock brakes.
PS I've never really understood what a transaxle is but I'll bet it's connected to this proper wheel drive somehow.
Transaxle is a transmission and differential combined into one package, and you wouldn't want both front wheels pulling at the same rate in a corner since the outer wheel has farther to travel and would cause wheel hop. And for braking, the front calipers/rotors are bigger since during braking, the weight/CG is shifted forward...don't want the rear brake locking up during hard braking.
  Z
