Joe Coppinger
"You can’t talk head gasket without talking water pump – a.k.a. the other thing that ruins your life for a few days if it ever fails on you. Elio said the water pump for the three-cylinder engine has been designed with a lower flow rate and will use curved-vane impellers, making the pump slower and reducing parasitic losses. That’s a plus when you’re dealing with somewhere in the neighborhood of 60 horsepower at the crank."
I'm sure everyone has read this by now.
I'd like to point out a product that I use in my mustangs. It's called Evan Coolant. (www.evanscooling.com)
This stuff is expensive I know at $55.00 per gallon; last purchased, but the benefits:
But enough I just wanted to bring this product to attention.. The Elio with products like this in the after market could be so much more...
- Boiling Point 375+: This means no blown head gaskets due to antifreeze and water seperation (also redeuces cracked heads)
- Protects Below -40: This means the block won't freeze and crack because the anti-freeze.
- Reduced Operating Pressure: I run this stuff in the car with 0 psi (cut radiator cap) and the I can remove the radiator cap while the engine is on (carefully) and there's no pressure relief like in "normal" cars
- Non-Corrosive: it means the it doesn't eat at the metal or the rubber..
- No Shelf Life: once you put it in - there's no need to check on it.. (but I still do out of habbit"
- Non Toxic - another green thing if someones counting the enviromental aspect.
