Spare Tire Questions
dgruis
smart do not come with a spare, but they do come with an air pump wired into the system. If the hole is small the air pump is designed to attach a bottle of Fix-a-Flat goop while you inflate. The Elio would be light enough that a set of Run-flat tires could be an easy solution.
