Suppliers And What They Will Supply
I was going through Elio's supplier list and wasn't sure what some of them do. So, I'd like to consolidate a list here of what a supplier will be supplying Elio. Let's keep this one on track and limit discussion to simply what they supply and not get into who they should use instead or any of that. You can post what the supplier generally supplies even if we aren't certain what they are supplying Elio. We can then go back and edit posts as the information becomes more concrete. I'll start in the next post.
Listed on Elio.com as Tupy, Tupy American Foundry Corporation has facilities in Michigan and Indiana as well as Mexico. They provide wholesale rough castings in iron and steel.
What they will supply for Elio: Unknown
Kenona, or rather Kenona Industries is based in Michigan.
Kenona Industries excels in the arena of high volume precision machining, providing components to the automotive industry’s leading distributors of steering, power train, and NVH control assemblies. Although typically a tier 2 or 3 supplier, Kenona products are found in Ford, GM, Chrysler, Toyota, Honda, Nissan, Mitsubishi, and Freightliner vehicles.
Our team encompasses expertise in a broad range of materials and products provides a single sourcing opportunity to our customers, allowing consolidation of supply base and logistical simplicity.
Kenona machines a wide range of metals, which allows us produce any custom component or part our customers may need. We specialize in gray and ductile iron, powdered metal, and a variety of aluminums and steels. Our versatility includes shell, investment, lost foam and/or wax casting, zinc die-casting, permanent mold, as well as steel and aluminum forging. We also provide E-coating, powder coating, and plating.
Hi-Lex produces window regulators, push and pull cables for: parking brakes, clutches, trunk releases, accelerators, shift lock, and cruise control.
What they will supply for Elio: Probably cables... who knows?
ElioMotors suppliers links ...
https://www.eliomotors.com/about-elio/#suppliers
A few have have a " LEARN MORE " link, most have just the name.
Yup. got it. Those that actually do have a description are fine. There are an awful lot of them that don't have a description at all and are just a name and logo. What do they supply? That's the point of this thread... researching suppliers and what they actually will supply Elio.
Johnny Acree
OK, here's one AirBoss
High performance anti-vibration
solutions
to the North American automotive market.
Read more +
AirBoss Flexible Products is one of the largest suppliers of molded and mold-bonded rubber parts in the North American automobile industry.
For more than 30 years, we have applied engineering talent and the latest molding technologies to solve every type of vibration problem for
America’s top automakers.
Think, muffler hangers, suspension bushings, motor mounts .
Johnny Acree
Anchor Mfg.
Automotive
Anchor’s core expertise includes small to large metal stampings and complex welded assemblies used throughout the vehicle including Class A appearance trim, structural, exterior, interior, exhaust, N.V.H., ride control, seating, steering column, brake, chassis, and safety related components.
Johnny Acree
About
World Leading Manufacturer of Precision Machined Crankshafts
Founded in 1943, Atlas Industries Inc. is world leading manufacturer of precision machined crankshafts for engines, pumps and compressors. Atlas has extensive experience in a wide variety of crankshaft designs, sizes and configurations. Products produced by Atlas can be found in a variety of markets including; Air Braking Systems, Air Compressor, Air Conditioning, Engines, Oil & Gas, Fluid Pumps and Refrigeration.
Our diversity in machining has greatly enhanced the scope of our product portfolio. In addition to crankshafts, we manufacture a variety of other products including; Balance Shafts, Cylinder Heads, Eccentric Shafts, Exhaust Manifolds, Exhaust Elbows and Tees, Hubs, Valve Plates, Scroll Shafts, Motor Shafts, Water Cooled Manifolds and Air Intakes.
Atlas operates two machining plants in Northwest Ohio offering in approximately 400,000 square feet of manufacturing space. Each plant is equipped with its own Quality Assurance Lab and stand ready to complete all necessary machining operations such as milling, grinding, drilling, boring, turning, broaching and other related machining operations utilizing over 1,000 major machines incorporating conventional production and CNC equipment. Both manufacturing facilities are ISO 9001:2008 Certified ensuring the highest quality standards.
