Today's Birthdays? The Usual?? 1/27
Hey....You asked!:rolleyes:
Calculating the probability[edit]
The problem is to compute the approximate probability that in a group of n people, at least two have the same birthday. For simplicity, disregard variations in the distribution, such as leap years, twins, seasonal or weekday variations, and assume that the 365 possible birthdays are equally likely. Real-life birthday distributions are not uniform since not all dates are equally likely.[5]
The goal is to compute P(A), the probability that at least two people in the room have the same birthday. However, it is simpler to calculate P(A'), the probability that no two people in the room have the same birthday. Then, because A and A' are the only two possibilities and are also mutually exclusive, P(A) = 1 − P(A').
In deference to widely published solutions concluding that 23 is the minimum number of people necessary to have a P(A) that is greater than 50%, the following calculation of P(A) will use 23 people as an example.
When events are independent of each other, the probability of all of the events occurring is equal to a product of the probabilities of each of the events occurring. Therefore, if P(A') can be described as 23 independent events, P(A') could be calculated as P(1) × P(2) × P(3) × ... × P(23).
The 23 independent events correspond to the 23 people, and can be defined in order. Each event can be defined as the corresponding person not sharing his/her birthday with any of the previously analyzed people. For Event 1, there are no previously analyzed people. Therefore, the probability, P(1), that Person 1 does not share his/her birthday with previously analyzed people is 1, or 100%. Ignoring leap years for this analysis, the probability of 1 can also be written as 365/365, for reasons that will become clear below.
For Event 2, the only previously analyzed people are Person 1. Assuming that birthdays are equally likely to happen on each of the 365 days of the year, the probability, P(2), that Person 2 has a different birthday than Person 1 is 364/365. This is because, if Person 2 was born on any of the other 364 days of the year, Persons 1 and 2 will not share the same birthday.
Similarly, if Person 3 is born on any of the 363 days of the year other than the birthdays of Persons 1 and 2, Person 3 will not share their birthday. This makes the probability P(3) = 363/365.
This analysis continues until Person 23 is reached, whose probability of not sharing his/her birthday with people analyzed before, P(23), is 343/365.
P(A') is equal to the product of these individual probabilities:
(1)
The terms of equation (1) can be collected to arrive at:
(2)
Evaluating equation (2) gives P(A') ≈ 0.492703
Therefore, P(A) ≈ 1 − 0.492703 = 0.507297 (50.7297%)
This process can be generalized to a group of n people, where p(n) is the probability of at least two of the n people sharing a birthday. It is easier to first calculate the probability p(n) that all n birthdays are different. According to the pigeonhole principle, p(n) is zero when n > 365. When n ≤ 365:
where '!' is the factorial operator,
is the binomial coefficient and
denotes permutation.
The equation expresses the fact that the first person has no one to share a birthday, the second person cannot have the same birthday as the first (364/365), the third cannot have the same birthday as either of the first two (363/365), and in general the nth birthday cannot be the same as any of the n − 1 preceding birthdays.
The event of at least two of the n persons having the same birthday is complementary to all n birthdays being different. Therefore, its probability p(n) is
This problem can be also solved as (1- partial permutation (365,number of students) / partial permutation (365,number of students) with repetition)
This probability surpasses 1/2 for n = 23 (with value about 50.7%). The following table shows the probability for some other values of n (this table ignores the existence of leap years, as described above, as well as assuming that each birthday is equally likely):
The probability that no two people share a birthday in a group of n people. Note that the vertical scale is logarithmic (each step down is 1020 times less likely).
n p(n)
1 0.0%
5 2.7%
10 11.7%
20 41.1%
23 50.7%
30 70.6%
40 89.1%
50 97.0%
60 99.4%
70 99.9%
100 99.99997%
200 99.9999999999999999999999999998%
300 (100 − (6×10−80))%
350 (100 − (3×10−129))%
365 (100 − (1.45×10−155))%
366 100%
367 100%
Thanks for your tireless work- I knew there was a simple answer! :-)
Well, the end is upon us, someone hijacked the birthdays, and I can no longer assume that they might be good or worth posting- With all the math I don't think four 26 yr olds (not related) have their B-Day on the same day!!
It seemed a good idea at the time
Do some quick math and it does make sense. Lots of people get married on Memorial Day weekend. Throw on a honeymoon...ta-dah! ;)
I checked it carefully- many are "new" members" w/no messages, joined the same months- check it out, someone's playing.
Not a big deal, not that it was ever accurate, but it's not worth anything under theses circumstances
Marshall
Texas
Any ideas
Any idea why/how that can happen??
Considering that there are only 31 days in the longest month and all the kids in a classroom PROBABLY share a birth year, it makes sense. Please note that sharing a birth DAY is not sharing a birth DATE which also requires a birth MONTH to be shared.
I would have thought you would have to be higher using probabilities alone for a birthdate.
I hear you, a close examination of the "members" with the same date (the are listed as birthday, and age - some folks didn't list age (which was cool) i.e., the last go round,had 4, all new, never a post, two each of the 4 started here the same month, no avatars . I've seen folks contribute extensive research that indicated a group of 33 folks have the same birth day! and different ages.
Thanks for the help, Whatever is/was going on, someone was screwing around, I was doing it as an exercise to see the age ., they don't pay me enough to pursue it.
Yeah, but I can look into it, there are a couple of tools that do it in case they are spoofed accounts.
Just PM me with names
