HonestTex
- Joined
- May 3, 2014
- Messages
- 442
- Reaction score
- 1,017
Thought that was for the fuel filler neck...Is that a subwoofer opening, right behind the doggy-door below the rear window?
You can register using your Google, Facebook, or Twitter account, just click here.Thought that was for the fuel filler neck...Is that a subwoofer opening, right behind the doggy-door below the rear window?
WHAT? It's not on the left side?If you're referring to the round opening, I'm pretty sure that is for the fuel filler.
Once again, the gentle wizard.
Of course it will increase the mileage.I like how with this new series, they made it float. No wheels on the ground has GOT to greatly increase gas mileage.
It only worked in TN, KY, and AR.Of course it will increase the mileage.
In the 60's and 70's, people put tall springs on the rear axle, raising the back of the car up higher. This caused them to point downward. This was done to make them go down hill and everyone knows you get better mileage going down hill.
I lived in the 60's and 70's we raised the back of the cars after installing "Gabriel air shocks" attach compressed air, shocks raise which lifts the rear body so that you could install wider tires (protrude out from the body without cutting the fender well).It only worked in TN, KY, and AR.
Watch it I live in Arkansas, not from here but I live here and I have heard ALL the jokes and ALL about a previous president that I didn't vote for.It only worked in TN, KY, and AR.
Yup, and don't go over railroad tracks at 50 with 6 people in the car; if you do, carry 2 spares, you'll need them.I lived in the 60's and 70's we raised the back of the cars after installing "Gabriel air shocks" attach compressed air, shocks raise which lifts the rear body so that you could install wider tires (protrude out from the body without cutting the fender well).
Only if you're facing the Elio.WHAT? It's not on the left side?
