- Joined
- May 6, 2014
- Messages
- 1,747
- Reaction score
- 5,007
You're right eh. That's why you need a trailer with a wheel track as close to that of the front wheels as possible.
My trailer will match the track of the rear wheel.
You can register using your Google, Facebook, or Twitter account, just click here.You're right eh. That's why you need a trailer with a wheel track as close to that of the front wheels as possible.
The pill bug or rolly polly is a good model for both trailers and fenders.
You know, that's a darned good idea now that you posted the picture. I am trying to think of something technical-ish but am caught up in the aesthetic.![]()
Should be fairly simple to fabricate a "reciever hitch" that bolts to the frame above the rear suspension swing-arm. This should easily fit (hidden) behind the black plastic wheel cover. So, when your not towing, the only thing visible would be a small access hole, about a foot below the license plate.... I fear the swivel point would have to encircle the rear tire of the Elio. I am not sure how well this would fit.
I went to their website. I would like to see the hitch. It would have to hinge in two axis. One axis for going over bumps and curbs,; the second for turning corners. However, the vertical would need a vertical pin to keep the trailer from falling over. I hope this is not too technical.
There's always this : Swivel Wheel TrailerI went to their website. I would like to see the hitch. It would have to hinge in two axis. One axis for going over bumps and curbs,; the second for turning corners. However, the vertical would need a vertical pin to keep the trailer from falling over. I hope this is not too technical.There must be a simple explanation.
Put two pivots in a row... one pivots up and down only and the other pivots left and right only... Should work.I went to their website. I would like to see the hitch. It would have to hinge in two axis. One axis for going over bumps and curbs,; the second for turning corners. However, the vertical would need a vertical pin to keep the trailer from falling over. I hope this is not too technical.There must be a simple explanation.
Should be fairly simple to fabricate a "reciever hitch" that bolts to the frame above the rear suspension swing-arm. This should easily fit (hidden) behind the black plastic wheel cover. So, when your not towing, the only thing visible would be a small access hole, about a foot below the license plate.![]()
