Thank You !!!i Broke An Ez Out Trying To Remove A Bolt *facepalm*
Ian442
York, PA
Broke a bolt for shock absorber on my van. Drilled a ton of it out, and thought oh i'll use and EZ out.
Dumbest idea ever.
Now not only do i have to drill out the rest of the bolt...i have to remove the EZ out too.
FWIW, no torch available.
I have left handed drill bits, dremel tungsten carbide bits, dremel cutting stones, and a tap and die set at the ready.
any help would be greatly appreciated since info is kind of sparse
KD
Texas
Dumbest idea ever.
I just read an article online a week or two ago about this very subject. The solution was your dremel tool. And a LOT of patience...
I've done that Once... Just once. I was lucky and was able to grab the end with a pair of vice grips. If you can't do that, your dremel might be your best bet... It's going to suck, that's for sure.
Dumbest idea ever.
Had a similar problem but got lucky.
Tried a center punch and for some reason it started coming out.
But to get to the possible solution........
Have you tried a "Grabit"?
You can get them at Lowes.
Ian442
York, PA
I will get more up to date pictures here later today...i drilled quite a bit out so i want to get you better photos than what i found on the phone i took when i first started.
