raptor213
I recall the Tour Team mentioning at the last NAIAS that they attended in Detroit (January 2017 maybe) that they were considering relocating the battery to the rear. But I was under the impression it would be stowed below the deck of the trunk, concealed by a trap door of sorts. If it will instead be mounted below the rear seat cushion, my first thought is: how do they manage that without infringing on the fuel tank? There hasn't been any mention of reduced fuel capacity."J- Jumper Cables- If you ever need to use your jumper cables in your Elio, the battery is located under the rear seat."
So they've moved the battery. Interesting.
But yeah, the battery getting repositioned to the rear was in the works at the same time the exhaust shroud was announced to be vanishing thanks to the switch to the unibody construction. I recall the fuel filler repositioning being part of the mix around that same time, switching from the right/passenger side to the left/driver side.
Not news per se, but we've certainly gone quite a while without any mention of these planned/announced modifications to the E1c.
