Diy Hands On Projects
Interested
Ohio
Worked on my hacksaw collection. Why might you ask? I love looking at all the different designs. Nickel plated some of them. Earliest ones have a lever to tension the blades. Made by George Griffin, patented June 5, 1883. Later became part of C.E. Jennings. From left to right: Disston 12", Unknown 8", Griffin 9", Griffin 8", Unknown 9", Unknown 9 1/2" (might be butcher saw), Star Clemson Brothers 8", Star Clemson Brothers 9", Star Clemson Brothers 10", Union/Adkins 8", Stearns file handle.
Sonoran Sam
Sonoran Desert - USA
Here is a new one for me and I'm wondering if anyone else has seen this. I was putting air in my motorcycle tire when the schrader valve separated from the rubber housing and shot out. There had been a slow leak for some time and I just assumed it was somewhere around the rim, but I was wrong. Very glad I wasn't flying down the highway when it spit itself out. For the record, I wasn't being forceful and actually using a bicycle tire pump to add air. I took it to CycleGear for them to look at, as they had installed the valve and tire a few years back. They had never seen anything like it, either and thought maybe it might be heat related. I keep my motorcycle in the garage, but my garage is not climate controlled. Scratching my head on this one.
Needless to say, this wasn't an easy fix. I had to tear down the whole rear of the bike to remove the tire/rim.
Sonoran Sam
I've had the rubber seal go bad on the valves used on rims with tubeless tires
Yes, I've had valve stems leak where they go into the rim and meet the metal, but never had one separate and come apart (like the one above)
I got up early (before it got too hot, here) and re-assembled my motorcycle. The hardest part is getting the chain aligned with the proper tension. I know they make a specific tool for aligning the chain... might have to invest in one.
Interested
Ohio
Currently working on a Millers Falls No. 97 breast drill. I agree with what others have said about it, it's a beast. Weights about eight pounds. Here are some before and after pictures. Getting ready to nickel plate and then paint some details.
Interested
Ohio
OK, I give up, do you sit on it? Or do you put your shoulder on it? To put your weight on it?
It's called a breast drill because you push on the end with your chest while on handle turns the crank with a drill bit and the other handle steadies with the auxiliary handle. The trick is to position the workpiece for best control. Think of the workpiece on a bench and drilling horizontal. You could also drill straight down with the drill higher on your chest.
Here is decent YouTube showing use:
Sonoran Sam
The turn signals stopped working on my girlfriend's car. She told me they this had been an intermittent issue and she thought the problem would "just go away". Well the turn signals went away entirely.
I ordered up a new relay and installed it this morning while she slept in. When she got up, I told her the car was all fixed. She thinks I'm some sort of "genius". I'm not going to tell her it took me less than 15 minutes to fix it.
Sonoran Sam
The weatherman is calling for 97(F) degrees next week. If he/she is correct, I may need to crank up my Evaporative Cooler. The only problem was two rust areas that needed to be fixed on the water pan. A new pan is $600 -- not an option. I picked up a tube of automotive seam sealer and "glued" on two patch panels (scrap metal I had laying around). My thought process is -- if it works for cars that drive 55+ mph in the rain, it should work for a static application?? I guess we'll see. I'll throw on a coat of paint later today and put it all back together tomorrow.
