CheeseheadEarl
Yes. BUT -AMTRAK is run by the government...the model of "efficiency"!It's ridiculous that Amtrack is the most expensive option given the efficiency of trains.
You can register using your Google, Facebook, or Twitter account, just click here.Yes. BUT -AMTRAK is run by the government...the model of "efficiency"!It's ridiculous that Amtrack is the most expensive option given the efficiency of trains.
Actually it isn't, but congress keeps preventing it from making necessary changes, then chipping in funds for useless boondoggles that they want Amtrac to do.Yes. BUT -AMTRAK is run by the government...the model of "efficiency"!
I'm selling temporary bras for the trip. Don't forget to clay your car as soon as you get it home.
If you're driving that far, don't forget about one thing.......Elio's special bug shield/deflector!!! Otherwise, you'll be picking bugs out of your spanking new radiator!
OK, I'll bite. bras? clay? :-) ZI'm selling temporary bras for the trip. Don't forget to clay your car as soon as you get it home.
A vehicle bra protects the front by covering it.OK, I'll bite. bras? clay? Z
Thanks for the explanation. :-) ZA vehicle bra protects the front by covering it.
USES FOR CLAY
Clay is not a cure-all or a replacement for polishing. It's a tool for quickly and easily removing surface contamination.
One of the many reasons for using a clay bar is the removal of brake dust. Brake dust contamination, which attaches to painted rear bumpers and adjoining surfaces, is a metallic surface contaminant that can be removed safely and effectively by using clay.
Pinnacle offers the most gentle detailing clay available on the market today. Pinnacle Ultra Poly Clay removes light to moderate contamination with very little effort. Its very low abrasive content reduce the chances of scuffing even the softest paint finishes. Customers report using this car clay as often as monthly with fantastic results.
Clay is also very effective on paint over-spray. If the over-spray is particularly heavy, you may want to seek the assistance of a professional. Tree sap and tar specks can also be safely removed with a clay bar. A heavier grade clay bar, like Four Star Ultimate Detailing Clay, may be more suitable for heavy overspray.
Recently, I have also started using clay on my windows (exterior) to remove heavy road film, bug deposits and water spots. It works very well, and seems to outperform even the best window cleaners.
HOW DOES DETAILING CLAY WORK?
Clay removes above-surface bonded contamination through the mechanical action of the clay bar rubbing against the vehicle surface. Detailing clay abrades the contamination, wearing it down in some cases, as a result of this mechanical action. However, detailing clay is not abrasive to the paint. The use of an approved clay lubricant prevents marring of the paint. The removed contamination sticks to the clay and is removed from the paint.
I'll buy one of your temporary bras.I'm selling temporary bras for the trip. Don't forget to clay your car as soon as you get it home.
