Atomic13 --- I believe you were given some bad info on several fronts. We were told sometime back about the Chrysler minivan rear A/C unit however we were later told the supplier could not supply the numbers needed. Same with the rear unit for the Nissan Quest unit. I believe both the Chrysler and Nissan units are not electric but operate from the same compressor as the front A/C. The IAV engine clearly shows the compressor mount beneath the water pump housing.
but I was wondering about that.
