Interesting. And upsetting. So it's fork over about $2K, and get lots of information, or stare at the spinning wheel trying to interpolate where within 20 mph my speed actually is. Actually, I know for a fact that Elio is well aware of the general loathing for the Elgin dash -- and perhaps something will come of that.For those who have not heard. In conversations with Elio VP Jerome Vassallo in Birmingham and Charlotte I was able to confirm that directly that the Elio vehicle will have a standard OBD-II connector and will be OBD-II compliant for diagnostic fault code scan tools and such. However, the Elio will NOT support the data streaming portion of the OBD-II standard so there will be no streaming sensor data which you need to run virtual gauges when using applications, such as Torque, which provide such functionality.
For those who may wonder as far as I can find the data streaming portion of OBD-II standard is not required by Federal law on any vehicle as the federal government apparently only really cares about using OBD-II for vehicle identification, safety, and emissions control purposes.
So even if the Elio vehicle were a car and not a motorcycle they likely still would not have to provide this data and could save money by using the inexpensive ECU/PCM which does not support hosting this data. Once again the very smart people working with Paul Elio have managed to find a way to save money while at the same time meeting the higher car standard instead of just the motorcycle standard.
Z
