- Joined
- May 2, 2014
- Messages
- 1,890
- Reaction score
- 4,667
Good answer, Ive never had to dead stick any of my helos, (they are all electric) and if I did have a main motor fail I am sure I would crash it, I haven't even practiced it, love to try it in a simulator though.No, propellors cannot autorotate in the helicopter sense! Multiple propellors on these quadcopters provide lift and control by differential thrust outputs. These aircraft are effectively "hanging on the prop" like an aeroplane going vertically then slowing to a stop. Helicopter rotors work differently, with constant rotor rpm and cyclic and collective pitch changes. Having a freewheel device built into the transmission system is only part of the equation. Don't forget that the main rotors of a helicopter provide lift as well as thrust. Once a helicopter's engine stops providing power, it is the airflow from below due to the rate of descent that provides the rotor thrust. In simple terms, the airflow through the rotors comes from below, rather than from above, as it is in the powered state. It's actually the inner part of the rotor diameter (nearest the hub) that provides the autorotative force which drives the rotors round/forwards in relation to the rotor mast. Unless a proper collective pitch change mechanism is present, "propellors" will rapidly slow down and probably stop. Once they no longer provide thrust, there is no lift and no control of the aircraft.
