Financing Elio Motors Development And Production
You can figure it would take 10kwh per hour of diving. A quote taken frm the Tesla forum about the pack cost from 2013..
Anyway, I found you could get the motor for $500, the controller for about the same, a pack for $3k, you might need a BMS ?300? and all the other bits and pieces for $500 more, then a charger for $200, all totaled for DIY? = $5000. So I would expect Blue-EV to quote around $10k-$20k
and this would be a 12kwh pack for $3,3k (shipped) and 210lbs .
NEW 11kW/h Battery Block 182V /60Ah=http://hybridautocenter.com/HAC4/in...new-11kw-h-battery-block-182v-60ah&Itemid=605
Other Supplier links
LiFePO4 Batteries = http://www.batteryspace.com/lifepo4cellspacks.aspx
A123 Systems Li-ion battery technology - YouTube =
Thanks, The evblue site is interesting. I was looking at kits from evwest obviously more expensive.
I recall Vassilio's comment on an interview video that there would be aproximately 25 prototype builds. The first to be sent off for tooling up the factory. The others for ride and drive events and testing. The ride and drive events scheduled specifically for the pre-order community. This indicates to me ride and drive events during testing and prior to production, not after delivery begins. The prototypes would be available and ready to roll long before production begins and the first deliveries. Why wouldn't the marketing team get them on tour?
When the E-series vehicles are ready for test drive events is not up to the marketing team. The timing on the ride and drive events will instead depend on when the engineering team reaches their objectives. These vehicles are being built for testing so they belong to the engineering team until they are released to the marketing team for refurbishment and reuse as test drive vehicles. My guess is marketing team will not be completely left out however they will likely only have a single E-series vehicle, and/or possibly an upgraded P4, during most of the testing time period. This will likely be used primarily for media test drives and other related marketing efforts.
Another item to keep in mind is that about half the pre-production vehicles will be destroyed in crash testing so even if they begin with 25 test vehicles there will only be a dozen or so left over and it is likely the engineering team will keep several of those for testing, especially software development, right up until the first vehicles roll off the line in Shreveport. This means that even if they begin with 25 test vehicles there will likely be fewer than 10 vehicles, and possibly only a handful, for the marketing team to eventually use on the early test drive events. Even 2-3 vehicles is likely enough for events limited only to early reservation holders however I believe many people are expecting a huge test drive fleet of 18-25 vehicles to show up during these early test drive events which is not going to happen unless there are some major changes to the plan as we know it.
The majority of reservation holders will likely have a chance at ride and drive events before they make their decisions however EM knows that it is very likely that reservations holders whose vehicles will be produced in the first 2-3 months stand a good chance of not having this opportunity. This is why EM has not promised this would happen but instead set a more general goal for these event happening around the time of first delivery. The reality is that to offer these ride and drive events to reservation holders before even the first reservation holder needs to make their choice this means that a good portion of the road testing would have to be wrapped up over three months prior to the beginning of production and that is cutting it tight as the road test vehicles will need to be refurbished prior to test drives and we have been told that our orders are supposed to be placed about two months prior to delivery. We can all hope this happens, as I know we would all enjoy the opportunity, however I try and dispel this misconception as much as possible so people are realistic and understand the reality that this very well may not happen for most of us who currently have EM production 'spot in line' numbers.
in addition the projections for the production of 25 test vehicles were made a good while back .... I can't help but wonder if today's financial climate will have any impact on the number of them that are actually produced .... nice to have and got to have can easily be two different numbers
Very good point. I am sure funding levels will be a factor in how vehicle testing is conducted. If EM has more money for testing they can build and test more vehicles simultaneously which speeds up the testing timetable. However if EM does not have as much funding available they simply build fewer vehicles and the testing process takes longer to the cover the same amount of testing with fewer vehicles.
Paul tends to try and stick to numbers he's quoted, even if dates were highly elastic.
And too, once you've allocated to build 10, the extra 15 are not that much more money. But he will not build more than is needed.
So I suspect it will be exactly 25, unless not all of the tests/uses have been identified. Which isn't likely.
Now if the funding were suddenly approved, (and before the 3-4th quarter of this year), then 'wish lists' may get more attention and the number could well go up. JMHO.
Actually 25 is not an exact number as even EM has allowed for wiggle room on that number. A Tech Talk states 18-26 as the number but also if you listen carefully they usually state the number of as 'about' or 'around' 25 or two dozen when they speak about this.
Up until this point, the prototypes have been built as a “one-off” for engineering purposes to answer specific questions. The next series of builds will be considered E builds where 18 to 26 vehicles, each numbered accordingly, will be built to address a specific mission (e.g., fuel economy) from which it will be evaluated against. It is also important to note that through each of these series of steps, the production assembly sequence, methodology and the needed tools are being finalized. Therefore, the objective is to prototype a vehicle for engineering as well as prototype the assembly process.
http://us6.campaign-archive2.com/?u=24b371802c83d81776b06aa68&id=e32f0f9f33&e
Kuda
NC
:D
GoofyOne, thanks for the clarification on this. I appreciate both your memory and your ability to track down past information. Apparently, like many others I thought one of the purposes of the Drive & Ride program was to allow perspective buyers to choose between AMT and Standard Transmissions among other things. Now that I know that this only another future "goal" it appears that those of us in the early production runs will have to make transmission decisions on Tech Releases by Elio and IAV. Those later in the production process will get the benefit of our comments.
Having vacillated back & forth I finally opted on the side of the 5 spd.
I figure if I don't like it &/or grow tired of the clutch pedal, or don't care
about autocrossing my Elio any more, etc., etc. I'll just trade it on the
new "TURBO" model w/auto when it comes out!!! :D
