You can register using your Google, Facebook, or Twitter account, just click here.http://www.autoblog.com/2015/03/06/bmw-m4-gts-water-injection-report/Yes. Water injection is massively under-appreciated. Can you please share your links?
The Elio engine uses a cooled Exhaust Gas Recirculation (EGR) system. The EGR system will be used to improve fuel consumption of the engine by reducing pumping losses and lowering peak cylinder temperatures which reduces NOx emissions. When the EGR is cooled it further reduces combustion temperatures and reduces engine knocking. This enables the engine to have a high mechanical compression ratio which helps improve fuel economy and performance. The EGR system is controlled by the ECU and will allow a specific amount of EGR into the intake manifold to be distributed into the combustion chamber.
http://www.eliomotors.com/tech-talk-v39-the-engine-part-2/
