- Joined
- May 24, 2014
- Messages
- 959
- Reaction score
- 2,182
The Atkinson Cycle is another bastardized term in the automotive community.
In reality, it is a standard Otto cycle engine AKA 4 stroke, with an additional pivot point allowing the piston to travel farther and/or at different speeds on each stroke depending on the geometry. This requires additional rods, bearings and support parts thus increasing complexity.
http://www.animatedengines.com/atkinson.html
The Toyota Prius claims to have an Atkinson Cycle engine. THIS IS NOT TRUE!!!
It is a MODIFIED Otto cycle engine with configurable valves, meaning, the intake valve can open during the compression stroke adjust the fuel/air charge to simulate the effects of an Atkinson cycle.
There are no additional pivot points, there is no change in piston speed or displacement. It's just variable valve timing.
A problem with most of the previously mentioned engines is the added complexity and development time of it AND their accessories.
Since they are relatively new concepts, the engines have to compete with Otto cycle engine that have been in developement for 50-70 years. Harmonics of the long connecting rods, unexpected cracking and specific metalurgical processes for each unique part will take time for the "lessons learned" phase.
The power curves might also be vastly different requiring transmission ratio changes, vibration and ware patterns that require additional material for strengthing which will require more weight which eats into the weight savings abd efficiency category.
All of these technologies need to be tested in an industrial sector first (connected to a power generator or water pump etc) to prove their worth.
