Slime Tire Sealant
Discussion in 'General Discussion' started by Jambe, Sep 13, 2016.
  1. Jambe
    Jambe Elio Addict
    1,269
    2,657
    Jun 2, 2014
    Top of Utah
    Reservation #:
    6100L, 9991L
    My JD riding lawn mower (D130) has crappy front tires. Have had several flats. Now I find at least three punctures from, guess what, puncture weeds. Instead of the usual plug I am thinking of using Slime.
    Any advice?
    These are tubeless tires and small (15 x 6). How much sealant should I use in each tire? Will it work to seal these miniature pin holes? Slime seems to be the brand that Walmart carries. Is there a better brand? TIA.
  2. CheeseheadEarl
    CheeseheadEarl Elio Addict
    765
    2,147
    May 15, 2014
    That's pretty much the ideal application for Slime. All 4 of my mower tires are Slimed.
    I think the small (16 oz?) bottle is what you want in a tire that size, but check the chart on the side of the bottle to be sure.
    Jambe likes this.
  3. Anderson Howard
    Anderson Howard Elio Addict
    126
    245
    Dec 10, 2014
    Sisseton SD
    Reservation #:
    4449
    My lawn had rosebushes and the rider mower tires had lots of stickers and about 3 ounces in the front and about 5 ounces in the back tire took care of most of the problem BUT the tire stores don't like to work on a slimed tire.
    Jambe and Coss like this.
  4. Critter
    Critter Elio Addict
    214
    556
    Feb 5, 2014
    Knoxville, Tn
    Reservation #:
    2579
    I use slime from tractor supply, rated for off road use only. Small can for front , medium for back. Happy with the results.
    Jambe and wizard of ahs like this.
  5. Coss
    Coss Moderator Staff Member Moderator
    9,980
    15,233
    Better slime than Fix-a-flat; Fix-a-Flat it's just take the tire off and replace it, no patching ever once it's been in there.
    Slime is what we used in the Antique Harley's, and they had tubes! The inside of the rim was brutal on tubes.
    Jambe likes this.
Share This Page
