Bikebrains
I noticed a characteristic of the Configurator that may be an issue. The situation in question is simple to create so I will use that method to describe the issue. First, launch the Configurator and select any color that is not close to the default color of red. Using blue, green or black works just fine. Now select Summary. On the second line of the summary the color that you have selected will be included. Now "print" the summary to a file or, if your browser displays the document before creating a file then skip creating the file.
Now for the issue: Using the finished summary, regardless of the color selected, the picture of the Elio appended to the bottom of the printed summary is a red Elio. I first saw the red Elio when I had ordered a white Elio. I began to worry about the order record that would be created. What would I get, a red Elio or a white Elio? The red picture at the bottom of the order could just be a static picture thus unrelated to the data in the order. If that is the case, why have a static picture that will cause confusion on every order that is for a color other than red? The confusion could possibly deter someone from placing an order. I am not going to place an order for a vehicle where there is that kind of confusion. Therefore, IMHO, if there is to be a picture of an Elio included on the summary, the color of the Elio should be the color indicated in the order.
