The Ever Falling Hp Of The Elio.... :(
How slow are you willing to go 0-60 mph?
  • the faster the better!
    Votes: 23 15.2%
  • under 8.0 sec
    Votes: 6 4.0%
  • under 9.0 sec
    Votes: 7 4.6%
  • under 10.0 sec (original Elio claim)
    Votes: 89 58.9%
  • As slow as necessary to ensure 84 mgp hwy
    Votes: 26 17.2%
Anybody remember that the Elio engine already has 12:1 compression,on regular 87 octane fuel.
How much more pressure will the cylinders/head gasket be able to handle?
And...at what cost to fuel mileage, or octane increase requirement.
You are right. Those are some of the reasons that "if" a turbo is offered, It will have to be more that a simple "bolt on". It will require a separate engine assembly line.
Not the head, the pistons. For cost purposes I'm sure the Elio engine will use cast pistons. To use any serious amount of boost will need forged pistons with much lower compression probably around 8 to 1 or less. An intercooler to get the inlet temp down and you're ready to rock. The bottom end appears to have cross bolted mains and to be pretty robust. Not really a weekend bolt on but well worth the effort.
I agree the compression needs to be lower for a Turbo and the amount of boost is also factor. I can see Elio adding a "performance" model in the future not focused on maximum MPG but maximum FUN!
Yeah, but traditional wisdom says you can't run "regular" gas at more than about 9.5:1 and Elio is set up to use it at 12:1. I'm going to guess Elio will come up with a solution or have a supplier who can figure it out.
