Three Wheel Weight Distribution
Robert "Bob" Woods
New Member
Nassau Bay TX
Has anyone seen EM address this issue?
Although Polaris hasn’t revealed the exact weight balance of the Slingshot 3-wheeled motorcycle, engineer James Holroyd says the rear wheel carries between 34 to 41 percent of the vehicle’s weight, which we can presume is the difference between the vehicle unoccupied and occupied. If too much weight is on the rear tire, the Slingshot won’t want to turn. Conversely, if the Slingshot is too front-heavy, the unloaded rear will have a tendency to snap out in corners.
booboo
Jelly Stone Park, CA
The Elio being front wheel drive makes a substantial difference too.
Agreed. It will be like any compact front wheel drive. All the weight in front. Elio has a long wheelbase, 110", so unless fatty is sitting in the back seat, a couple of heathens could probably pick the rear end off the ground. The driver sitting in about the middle of the wheelbase length should be enough added weight to keep it on the ground.
As others have pointed out, the Elio is Front Wheel Drive; while the SlingShot is Rear wheel Drive.
Besides the weight (and power) difference the drive wheels make a big difference on handling characteristics of the vehicle.
That 173hp in the SlingShot will snap that vehicle around and upside down faster than you could ever respond.
At 55hp-60hp fwd that's not going to happen.
