Momentum V93?
I think they lost count on the news letters or it should be v93B; any how, here's this week's:
Elio Motors Momentum v93
Through the course of automotive history there have been several developments that have proven to be true game changers. The implantation of features like seatbelts, airbags, turn signals, and headlights have made vehicles safer and easier to drive. Exterior lighting, in particular, has made vehicles much safer by increasing visibility and made it possible to drive at night. Today, we will take a look at the exterior lighting of the Elio.
During the development phase of the Elio, dramatic changes were made to the headlights. The headlights seen on the P2 and P3 were much different than the headlights on subsequent iterations. On the P2 and P3, the head lamps were mounted on the body. Beginning with the P4, the headlights were flush with the body of the vehicle. This change was made to decrease drag and improve the aerodynamics of the Elio. This design change was crucial in our mission to produce an ultra-high mileage vehicle.
Here is a photo of the P3 and P4 side-by-side to show the change:
Once the decision was made to make the headlights part of the body, we needed to finalize the design of the headlight. There are several determining factors when it comes to the headlight design including cost, electrical architecture, and energy budget (the amount of energy needed from the alternator.) Other factors, from a more macro standpoint, include aerodynamics, aesthetics, and weight. And, of course, optimum visibility is paramount from a safety standpoint.
Currently, there is no rating system for headlights, however this may change in the future. To ensure that we will be complaint in the event of necessary ratings, our engineers have been tasked to optimize the amount of light that is produced. While the Elio will not be registered as an automobile, we will use two headlights for obvious safety purposes. Our design is mounted lower than most vehicles, and with the split lighting we believe we can avoid the glare for oncoming traffic, as well as pedestrians.
The current direction design utilizes a reflective-style headlights. We are using reflector-style headlights to keep costs down, however these headlights do command a large segment of our energy budget. In the future, we are considering using a projector-style LED headlamp which would require significantly less electricity. The costs at the current time, however, do not fit in with our value proposition. If costs come down, we will strongly consider changing from our current reflector design to projector, LED headlights.
The rear exterior lighting is equally important in regards to optimizing safety. We have one taillamp which reaches approximately 22 inches across. We are using a total of five incandescent bulbs. Two are located on the right, two on the left, and one is placed in the center. The outside lights are brake and turn signal lights, the two inside lights are running lights for visibility, and the center light is a back-up light. Along with our suppliers, we are exploring the possibility of using LEDs for the rear exterior lighting. As with the front lights, the decision will depend on reasonable costs, as well as proper luminance.
*MSRP for non-refundable reservations only and applies only until non-refundable and refundable reservations total 65,000. Total current reservations can be seen at: eliomotors.com. MSRP excludes destination/delivery charges, taxes, title, registration, and options/installation.
Certain statements in this email including, but not limited to, statements related to anticipated commencement of commercial production, targeted pricing and performance goals, and statements that otherwise relate to future periods are forward-looking statements. These statements involve risks and uncertainties, which are described in more detail in the Company’s periodic reports filed with the SEC, specifically the most recent reports which identify important risk factors that could cause actual results to differ from those contained in the forward-looking statements. Forward-looking statements are made and based on information available to the Company on the date of this email. Elio Motors assumes no obligation to update the information in this email.
"While the Elio will not be registered as an automobile, we will use two headlights for obvious safety purposes."
HAVE THEY NOT EVEN READ THE FEDERAL REQUIREMENTS FOR COMPLIANCE CERTIFICATION YET??? :tsk:
https://www.law.cornell.edu/cfr/text/49/571.108
https://www.nhtsa.gov/cars/rules/maninfo/mcpkg002.pdf
Wow! There's 15 minutes that I'll never get back! :confused: Was there a specific paragraph in either of those links that contradicted what EM blog stated? If you're upset about them not using LED's, there's conversion bulbs in the aftermarket right now.
http://www.xtralights.com/all-products/hid-led/led-conversion-kits
IMO, there should be a disclaimer when a link is a down load. Link is a PDF download 0.97MB
BooBoo, the link has a very visible pfd file extension.
Please set your browser settings so that you get a notice that not only tells you it's a pfd file...
But also gives you a choice whether you want to download it or save it. Pretty simple.
I'd say the obligation is on your part, not on ours.
Nope. That's not the issue. Regardless of what other lighting they have, MCs must have a single headlamp in the middle of the vehicle or two headlamps less than 8" apart evenly placed to the vertical center line. And that's whether they're enclosed or not. Only two exemptions have ever been unofficially granted. Those were granted to VERY WIDE enclosed 3-wheeled MCs with side-by-side seating.
Nope. MCs must have a single headlamp in the middle of the vehicle or two headlamps less than 8" apart.
You missed it.
Not being registered as an automobile does not automatically imply that it's a motorcycle...because it's classified as an 'autocycle'. If that were the case I'd have to wear a helmet and take a motorcycle safety course in MO to drive the Elio. I didn't miss anything. You read into it words that weren't there.
It is NOT federally classified as an autocycle yet. The requirements for MCs I described are in there. What's NOT in there is the Feds classifying an enclosed MC (the Elio for example) as an "Autocycle". That has NOT happened yet. The various helmet stipulations have to do with the individual state laws and nothing at all to do with Federal standards for compliance certification. Nothing.
  • Like
Reactions: Ekh
