Ralphe
Good Thought!I've been considering the fact that the rear tire will be constantly traveling in "no man's land" that is not swept clear of road debris nearly as much as the traditional tire paths, therefore it is the most likely of the 3 wheels to be punctured and also the most difficult to change, If it is even possible to do so on the road side. Not the best situation. I think they should look into a non-pneumatic rear tire if there is anything at all that will give close to an acceptable ride and tune the rear suspension to deal with it. The rear tire does not need as much traction as the front tires, like in most FWD cars it's just supporting weight and "along for the ride". Not entirely of course, it has to have some lateral traction for cornering but compared to the fronts it's pretty much just getting towed around.
Z
