The Manual transmission is the ONLY transmission in the Elio. It will be either controlled with the clutch pedal and gear shift like a regular good old standard or it will be controlled via some actuators and software. Either way, the transmission, final drive ratio, number of gears, etc. is the same... since it's the same transmission.Anyone know the gear ratio and if it's 3 or four speed automatic.
The choice is "Manual transmission" or "Automatic Manual Transmission"... The innards are the same.
