Hello,
Can we try to put together a list of parts that are existing parts and which are new parts? I keep reading this notion that "the majority of the parts of the Elio are existing parts", but I can't quite see it. So let's try a list to get a better understanding. Please add to the list by copy->add yours.
OLD-- 23 parts
Brake Pedal
Brake Vacuum servo booster
Brake Calipers
Brake Discs
Brake Caliper carriers
Brake caliper slide pins
Brake caliper retractor springs
Engine/Trans: alternator
Engine/Trans power steering pump
Engine/Trans: parts of transmission
Electronics management, wiring harness:sensors
Electronics management, wiring harness: obd I plug
Electronics management, wiring harness:connectors
Electronics management, wiring harness:relays
Exterior: turn signals?
Exterior: side windows?
Exterior:
Exterior:
Exterior: prop rod
HVAC/ entertainment /comfort & convenience: electric window lift regulators
HVAC/ entertainment /comfort & convenience: fans
Interior: Seat
Interior: steering wheel
Interior:
Interior: shift lever or knob
Lighting:standard bulbs
Lighting:interior lighting housing
Suspension: none
Wheels/Tires: Wheels
Wheels/Tires: tires (not new but rare and hard to source?)
NEW: ~450 parts
Brakes: hydraulic tubing and hose
Engine/Trans: ~300+ new parts to new engine
Engine/Trans: radiator
Engine/Trans: mounting brackets
Engine/Trans: engine mounts
Engine/Trans: transmission mounts
Engine/Trans: axles
Electronics management, wiring harness:ECU
Electronics management, wiring harness:TCU
Electronics management, wiring harness:wiring harness
Exterior: body panels
Exterior: front window
Exterior: rear window
Exterior: door gaskets
Exterior: trunk gaskets
HVAC/ entertainment /comfort & convenience: compressor
HVAC/ entertainment /comfort & convenience: molded ducts, housing, filter
Interior: dash
Interior: carpet
Interior: molded interior panels
Interior: interior trim
Lighting:headlight housings
Lighting:Tail light housings
Suspension: ~80 new parts
Wheels/Tires: hubs
OLD-- 23 parts
Brake Pedal
Brake Calipers
Brake Discs
Exterior:
Exterior:
Exterior: prop rod
Interior: Seat
Interior:
Suspension: none
NEW: ~450 parts
Engine/Trans: axles
Interior: dash
Interior: carpet
Wheels/Tires: hubs
