You can register using your Google, Facebook, or Twitter account, just click here.Assuming 100% efficiency (which exists nowhere), 746W = 1HP.
It will take somewhere around one horsepower for the alternator to source 50 amperes. You can run a lot of stuff on that.
Electric heat is 100% efficient.
My old Previa van has a valve in the refrigerant line that opens when the rear fans are turned on. There is one for each side with separate speed controls. So no extra energy is used if you leave those fans off.They come both ways. Usually on some larger vans you can find the electric AC in the back. If no one is back there, no need to even have freon going bach there.
That's good to know...I was always under the impression that the mechanical force required to turn an alternator never changed...learn something new every day...
