Mel
Yes. It is a pusher gyroplane. No power on the rotor.It's different, how does it work with no tail rotor?
Or is it a pusher gyrocopter?
You can register using your Google, Facebook, or Twitter account, just click here.Yes. It is a pusher gyroplane. No power on the rotor.It's different, how does it work with no tail rotor?
Combine 2 complicated things and you get something that does 2 jobs poorly.
And nothing that flies cost less than $200,000
..not quite accurate, for example a ZENITH CH650 can be had for less than $100k, and a slightly used one for half that -
I think you mean "weighing over 254 lbs." See FAR part 103 (ultralight vehicles).Keep in mind any vehicle capable of flight (weighing over 150 lbs) will require a PPL or SPL certificate to operate.
Fly OK, maybe -- but it takes up 3 lanes minimum which will make it unpopular on the roads!And you can build a kit plane for under $15,000.
As far as flying cars go, though, I think a better way to go might be the FanWing concept. The rotating wing provides both lift and thrust, STOL capability, and doesn't require ailerons. Furthermore, the tail fins are part of the wings. Basically, you got a motorized wing section that you can plop down onto just about any car frame and make it fly. And with a lifting ability of about 15kg per HP, an Elio could probably fly with a bolt-on kit!
FanWing LSA concept
How it works:
Especially on a 2 lane roadFly OK, maybe -- but it takes up 3 lanes minimum which will make it unpopular on the roads!
