Nate_tx
I hope while you were looking at yourself, you did not run over anyone?
Actually it will have a connection port for trouble codes. It seems I read a post yesterday suggests the ECM in the Elio will not stream the data in real time out the port thou. So live Temp and other information may not be available through that port like it is in my Toyota. My 98 Diesel Suburban even streams some portions of its data live including RPM, Coolant temp and ambient air at intake. Seems the Elio to control costs (which is understandable) will use a more basic ECM that a lot of cheaper cars use. It will still finite control of engine parameters it just wont stream the data. So I do have a question - if the SkyZ package - which is supposed to have all that data does display engine temp and fuel and all of that - will that vehicle have a diffrent or upgraded ECM to support it?
