Are you saying it weighs more?Weight
Why does the blog say otherwise?
Quote: "It offers significant weight savings over stamped steel and other metals,..."
You can register using your Google, Facebook, or Twitter account, just click here.Are you saying it weighs more?Weight
Actually, SMC has a raw material to cured component of around 3 minutes. The SMC comes as fiber infused resin slab. They slap it into a heated mold of the component [male/female], and the heat and pressure form the component. Very quick, very easy, fairly durable final product, dimensionally stable, and the tooling is much cheaper to produce.
This site explains the process nicely:
http://moldedfiberglass.com/processes/processes/closed-molding-processes/compression-molding-process
Before we start gathering to burn down the plant can we see what Elio Motors has to say?
I sent them an email addressing what I was last told vs. what we have learned from the videos that were put out.
As soon as I get a response I will post it here.
Fiberglas, specifically, is heavy stuff. Nowhere near as light as more modern composite plastic materials. But you said fiberglass.Are you saying it weighs more?
Although we use prepreg composites. I was unaware of this process. It does alleviate my concern. Our cure cycles are much longer.
So is stamped metal (steel?)? Or not? Curious, but I can live with steel or SMC since I believe the weight will be similar with either steel or SMC (from recent posts). Unclear from recent posts if the panel material has been decided? I believe aluminum or carbon fiber panels would have to be aftermarket options? To keep the base price at $6800?Fiberglas, specifically, is heavy stuff. Nowhere near as light as more modern composite plastic materials. But you said fiberglass.
Elio WAS planning on composite plastic body materials. They may have changed their minds -- and judging from the language used, I believe they have changed them, to stamped metal panels instead. The may --or may not -- be heavier than the original plastic material would have been, may or may not be as costly or hard to procure in quantity, and may or may not offer good corrosion resistance.
All TBD.
This change may also mean changing the method of attaching panels to the stamped unibody frame. That has both engineering and manufacturing implications. And depending on just what material they do use (you can bet it's not going to be titanium), the ability to remove and repair it after an accident may change too.
In short, changing the skin of the car echoes up and down the chain. It's not a trivial change, and if it happens, it's being introduced very, very late in the design --quote-- test -- validate -- manufacture process. You don't make signifiant design changes at this point unless you have a very good reason.
For the record, I didn't say fiberglass, EM did.Fiberglas, specifically, is heavy stuff. Nowhere near as light as more modern composite plastic materials. But you said fiberglass.
