What Is The Latest Start Production Date?
Status
Not open for further replies.
electroken
Shelton, Connecticut
Looks like it might be a pain to replace the alternator.
This got me thinking about the last alternator I had to change. It was in 1992. The bearing on the pulley end was a little loud in my 1984 Celica GTS. Actually, all I did was replace the bearing and the rest of the alternator made it until I sold the car 3 years later. I guess the point is that alternators don't fail as often as the used to.
AND unpainted the insignia?
It could happen. A quick pass with a sandblaster and it would be "unpainted" ;). They also could have made an aluminum timing chain cover, to replace the clear one, closer to what will be used in production models.
Or, it might be a completely different engine. :confused2: :becky:
Marshall
Texas
By the time they get through making changes to fool us, they could have built another new engine... which is what I think they did.
The engine is the one part that should have been off the self and readily available. Difficult enough to get a new vehicle to market let alone a new ICE. IMO
slinches
Phoenix, AZ
Off the shelf engines are not easy to find for most derivative applications that fall in normal ranges of power/rpm/weight/efficiency/emissions ratings. I'm not surprised the Elio needed something different given that its design is half way between a motorcycle and a small car.
johnsnownw
Minnesota
Sure, but that engine was designed specifically to achieve mpg numbers to qualify for the ATVM loan program that Elio claims they don't require.
Seems using an off-the-shelf engine, initially, would have allowed them to enter production sooner...
Status
