Diy Hands On Projects
Made in USA
ohio
Have you ever made a chess set?
Nope. Too busy with other things. About to make stair spindles for a niece and still have some work to do on the tool cabinet. Here's latest picture with additional drawers and cleaned up a little:
Those french curves over on the left bring back memories of when I did drafting. I have two sets. One is a nice set of SS ones and the others are cheap clear plastic. I ended up using the cheap ones because they worked so much better and you could see through them.
Made in USA
ohio
These French curves are from Lost Art Press. They are made from bamboo plywood. They are somewhat flexible and you can mark on them. Also, the edges are straight up and down (no bevel) so they can be flipped over. Lee Valley also sells something similar.
What made the SS ones nice was when you needed to erase a curve. Stick it just next to it, flip the switch on the eraser and go to town on it. The clear ones were nice because you could lay it down and at least try to imagine what it was to look like before you put pencil to paper. I still have my old compasses that were from the 1940's that I bought used in the 70's. It had all of the doo dads on them too. Years ago, I took them all apart, cleaned them up, polished them and reassembled. Put them back in the case where they sit in my office. Even the containers that hold the needles and lead are metal and slip fit where they look like a big pill. One even still has spare screws and hardware in it.
Made in USA
ohio
I'll bet you even have the tips for ink. One step up from feathers. I too still have an electric eraser. Haven't used it in years.
I did learn how to fix my electric eraser because they were pretty expensive and it was worth it to fix it. Typically the bearings would start to go. I remember, one of them that I had, I ended up finding some really expensive Japanese bearings for it and having to put the shaft in the freezer and the bearings in a toaster. Then quickly, drop the bearing on the shaft, place them and then they were there for life. It worked great but then the winding took a dump and I had enough. It went into the garbage. That was right where I was doing CAD most of the time, so I never needed it any more.
W. WIllie
Campo Ca.
I remember back in High School when I was taking drafting, we did our own blueprints by hand. Mix the solution, dip in the drawing, put between two sheets of glass, put out in the sun, and after a while, a blueprint was completed. The hardest part of drafting was the "pictorials", having to plot each point of the view on a curve was stressful. .
Now, I guess they just push the "print" button.
I will admit, it's much better today but that "print" button is rarely used now. I have a wide format printer that I got 20 years ago and I bet I have not printed anything off of it in 2 years. Everyone just wants a file. Then, if you are doing complex curves you just note the file number because it's impossible to represent what it is with dimensions. Best examples are just look at any recent car. The bodywork or just the dash, those are all done with basic measurements and then the rest is just referenced in the file. Even with machinery (that could easily be a paper print) most machine shops just have a monitor out in the shop and then they just reference that for what needs to be done. Thus, if you mess up on not including a dimension, they just look back at the file and get it. I love seeing how far technology has come. I'm living through the golden age right now.
Made in USA
ohio
During quarantine last week I worked on some spindles for my niece's 1888 house. She wants to restore the house best she can and some of the spindles were broke or missing. They are turned from red oak. She will cut to length and stain/finish them. She said she feels bad that I am making her "fancy" spindles when mine are so plain. I told her that mine are appropriate for a 1956 house. She want nine, but I'm making her twelve. Doesn't hurt to have spares.
we spend about 6 months a year traveling in our camper .... 3 in Texas and 3 in South Dakota .... we enjoy shooting and load our own ammo .... for years I've toyed with putting together a portable loading kit .... well, I've finally done so it is based on modifying trailer hitch .... the hardest part was reaming out the hole to enlarge it enough to accommodate the 3/4" pipe .... extra counter space will be provided by TV trays .... the reloading station can be quickly and easily disassembled for storage .... the only issue that remains is eliminating the movement from the space between the sides of the hitch and the receiver walls .... a clamp is on order that is designed to eliminate the movement .... the first 10 rounds have been produced
