The HVAC thing can just be a heat pump (which I bet was what they were looking at). Issue is, that would take the perfect 102 miles per charge lower. Then if you were on the highway that 33 miles would be really low. The windscreen will block the airflow and thus, make it hotter as opposed to riding a motorcycle. We make fans for a reason. For any of you are old, remember that cars without AC, you had those corner vents (i.e. what VW had). It directed air toward you.
If you live in an area that actually gets cold, you have another issue. You want heat. You could be the perfect person and keep it in a heated garage, plus wear a ski outfit then you are set for a while. Then again, you are having to go to extremes to make the product work all while you have a low tolerance for things like being really cold.
So, it seems like the company is suffering with a case of where the EV industry has moved on and the better right sized industry (e-bikes) have taken off. Main reason for that is the cost vs what you put up with. People can put up with a $2K e-bike as opposed to a $25K FUV. When the e bike needs help, you pedal it. I know this is not an option for old people but the younger ones with lots of money to spend, do.
