Avards
TY:Good point. And, you are mostly right. But, in most start stop systems, the accessories are electrical so they'd keep running. The battery has to be a bit more robust to keep it going. During extended stops, the engine actually starts back up to save the battery. Mazda actually had a system that cleverly stopped one cylinder in just shy of top dead center position and when you lifted your foot off the brake, would fire that spark plug, kicking the motor backwards building pressure in a cylinder which then fired it around the right way. This starts the car faster then your foot can make it from the brake to the gas... unless you are heel to toeing it... Down South (I'm from Georgia), you'd definitely want the AC to keep running. You don't see many start stop vehicles in the states because the U.S. cycle of testing doesn't favor the system. In other words, the EPA MPG listed on the window wouldn't change much. In Europe (I happen to be in Germany for work this week), a lot of cars have the system. Their test cycle has 40 seconds of idling which favors the start stop system cars. So, the manufacturers make them. The guys I'm here with can't get used to the car's stopping (a Mercedes wagon and a Mini) so they disable the system. I don't mind it. Anyway, actual driving can see between 3.5 - 10% increase in mileage. The cost is about $300 (says Ford) per vehicle.
Thanks for your response.
In that response you state: "But, in most start stop systems, the accessories are electrical so they'd keep running. "
Does that include the a/c? Is the compressor electrically driven?
Again, I'm not the least familiar with the sss concept, so I'm using this venue to gather information.
I'm all too familiar with the cool temperatures in ATL. Worked at Dobbins for over a decade.
Thanks,
wr
