If you have fuel injection, you're actually using more fuel coasting than you are if you leave it in gear with the clutch engaged.I THINK I HEARD MR ELIO HIMSELF SAY THAT, MAYBEI READ IT...BUT the source USED THE REASONING THAT THE( oops caps abuse)...but too lazy to start over....anyway the auto trans knows the perfect time to shift, saving fuel. but you know what? in my Hyundai I gave away to son and on my motorcycle I coast a LOT of the time. in the car I simply shifted the 5 speed to neutral , on the bike I just pull in the clutch handle. in fact I wish someone would invent a tranny for a motorcycle that would allow you to go to neutral without going thru the gears like you can in a car with a manual tranny. does this make sense? its easier to replace brakes than engines or trannies and I rarely use the engines compression to slow down.
Coasting uses fuel at idle to keep the motor running. Not coasting while not on the gas theoretically uses no fuel.
That's true on a vehicle with fuel injection whether has a standard, AMT, or conventional auto tranny.
Now... On a carbed bike, why in the world would having the clutch in not be enough? Why would you need to pop it into nuetral?
Long hills and carpal tunnel?
