What is a dehumidifier?
I got the same response trying to explain a swamp cooler when I moved out here.
You can register using your Google, Facebook, or Twitter account, just click here.What is a dehumidifier?
They've made some advances in design since then. The "balloon" (dome form) is much better than the vinyl used in the '80s; 2" to 3" of polyurethane foam are sprayed over the inside of the balloon. When the foam sets, U-shaped rebar is punched into the foam in a specified pattern that avoids where the windows and doors will be. The shotcrete (concrete mixed with nylon fibers to allow the material to be sprayed) is then sprayed on the foam over the rebar, creating a reinforced concrete shell. The combination of the dome form and the foam form a waterproof barrier that minimize water seepage; that and current standards in thermal and moisture barriers in pouring foundations means the interior of modern monolithic domes is usually very dry and remains so.One style which was popular in the '80's was a 'shotcrete' covered vinyl 'balloon', which created a real nice hemisphere which they then bulldozed a few feet on dirt on.
Jeff is correct, just because it is built to IBC means very little, local jurisdictions utilize their own codes, many do not even recognize IBC. I was an IBC inspector for PFS corp. for awhile. You will have to get a building spot with no zoning controls to pull one off properly. NFS codes (Fire codes) dictate the amount, position and size of windows which can completely ruin the design of these.
The company I'm looking at can do custom designs for a $1-per-sqare-foot deposit. But looking at the generic designs they offer, I think they already have the requisite doors and windows for fire code. This plan is a 1700+ square foot design. The only thing I dislike is that I think 3 bathrooms is overkill.
