Radio Questions/audio Questions
Grumpy Cat
Rather than running it through the radio, get a low cost set of walkie-talkies and a mono headset with a mic (you can't legally wear headphones when you drive).
Yes, I know someone will pop in and say that they use two earbuds all the time, but if you got pulled over with them in, it's a ticket.
Having both ears covered (or filled) makes it difficult; if not down right impossible to be able to hear warning sounds when you drive.
It actually depends on where you live:
http://drivinglaws.aaa.com/tag/headsets/
Is this a single DIN or double DIN? I thought DINs had square corners and not round ends.
How do we fit a DIN stereo into this hole?
I can't imagine it being anything else than single DIN. The aspect ratio of the opening looks too high for double DIN and I can't see EM deviating from such a widely accepted standard.
If you look at pictures on the configuration, the radio sure looks to be no larger than single din.
A question for you "electronic" wizards: is it possible (at reasonable cost) to run a vox intercom through the radio/stereo system? Perhaps just an amp and speakers with music input (blue tooth?) from the intercom side. I guess I have become obsessed with having a clip-on mic for each of us to help eliminate the feeling of isolation (not to mention headsets). Any others see the value in this?
I think I'll wait and see how loud the cockpit actually is before thinking about something like that. I'm expecting the Elio to be quieter than I expect....:brick::confused2:
Top
