Elio Fenders...retro-futuristic?
So, I was wondering what the Standard fenders would look like without the black plastic skirting. To find out, I opened up the Configurator, screen-captured both fender types, then layered the Retro fender underneath the Standard (after deleting the skirt).
Even though I didn't bother photoshopping out the Retro fender, I think it gives you a pretty good idea of how cool the standard fenders can look without the skirt. But the lines on the Retro fender also add some pretty need flare, don't you think?
As a note: I think going without the skirt might cause rocks/mud to get flung all over the side, so it's probably a bad idea. But it looks cool!
KD
Texas
Interesting look for sure. And those wheels!
I like it. Stock fenders, no skirt but rather a close fitting rear to keep mid down. Since the Elio can be stuck with only driving around town for commutes, aerodynamics doesn't play into things much. I could totally see going with your look there.
{Stubbornly continuing to use italics to refer to the Elio just like Elio does in their blogs... grr}
booboo
Jelly Stone Park, CA
Nicely done Sethodine.
Stock Fenders are cool enough for me to start. I bet once early adopters hit the streets, so will ELIOPHORIA. Then, we will see after market custom parts. After all, it will be the American Peoples Autocycle. We'll have dozens of custom front wheel covers to choose from in a year or two.
Am I excited enough yet.
floydv
California
What would be really cool to me is a set of retractable fenders that can go from essentially open wheel to fully enclosed. One model could be based on the armored helmet from the Lost in Space movie:
Maybe comprised of nested, semi-circular FRP arcs all joined at a hinge point? The fully enclosed mode could still retain some of the aerodynamic benefits of the stock fenders at highway speeds, while the open mode allows you to show off your rims around town.
Now that's what I call "thinking outside the box" Well done! :thumb:
I've seen some of Silas Sundays pics of the aero fenders with the sides cut away exposing the wheels. Pretty sharp with alloy wheels. Don't know how much it would take to beef up the fenders after removal of that much material but it would be fairly simple to do.
If you just remove the removable fender rears (the black part is removable stock), it shouldn't affect the fender at all.
