Informative Video
Jeff Bowlsby
San Ramon CA
:cool:
Rob Croson
Ohio
Yeah, that radio looks oddly shaped. Maybe it's a single DIN, but with rounded corners? Maybe if you squared off the corners of the fascia, it would be single DIN? In which case, maybe it's standard mounting arrangement on the inside, and just a strange fascia plate.
floydv
California
Under the plastic fascia with the oval opening:
From that picture, looks like it could be a standard single DIN or maybe even a double DIN hiding under that oval fascia. So perhaps all we need to do is remove the fascia, install a standard headunit, then replace the fascia with an aftermarket fascia.
hawg_ryder
S.E. Texas (Gulf Coast)
I hope that's the case! I had planned all along to install a unit w/retractable screen... The Skyze unit is way too pricey for what you're getting... Here's hoping the gauge cluster shown here is what they go into production with... Offer the Elgin as an option... That should satisfy everyone I'm thinkin'
h_r:cool:
h_r:cool:
Elio.jpe
Jun 30, 19:00 EDT
Hello Coss!
Thanks for checking in.
Great eye! The dash you see is a placeholder, as this is not a public vehicle and will be used for testing. However, the electronics and spacing are the same. At this stage, there are no plans to offer an optional dash.
Thanks again!
Best,
The Elio Team
The instrument cluster will be the Elgin only, period.
If you want something else, it will have to be aftermarket.
I already have plans for the gauges I'm using; someone else that is getting one of my setups named it the "Coss Cluster"
