Elio Motors Names Flame-spray Industries As Supplier Of Cylinder Coating Technology
H2odog
Where do you get that the reference was inferred.
I would much rather have the durability of a corolla or a civic over either of the two automobiles that were given as examples. Those high performance engines could also have something that aids in the longevity of this technology that is cost prohibitive to economy cars (under $100,000).
Just saying if you are gonna tell me that something is gonna be used in an economy car, then it should be proven in economy cars. If it is then let someone post the economy car it is used in. Which makes a lot more sense.
Are you simply argumentative or do you just lack vision? You know, if Mr. Ford and a few others thought as you do we would still be going to the blacksmiths shop to have our wooden wheels iron rimmed.
Farm Boy
One reason maybe is that it makes the engine a "non rebuild-able ". If one of the cylinders is damaged for some reason you cant just bore it out and put an oversize piston in. As long as you take care of your engine and you do something stupid like drive it with no oil or no water, the engine should last as long if not longer then the rest of the car.
Craig
SE OHIO
A new innovative process, known as Plasma Transferred Wire Arc (PTWA) spray, solves the problem by applying a spray coating to the cylinder wall to return the bore to original equipment specifications. In addition, the spray-welded metal coating of the PTWA process also creates a more durable wear surface, as well as producing a more fuel-efficient engine. At the current production rate, PTWA prevents more than 5 million pounds of iron from entering the scrap process each year.
http://www.jointeamcaterpillar.com/cda/layout?m=389975&x=8&ids=4360867&printerFriendly=true
Craig
SE OHIO
Too bad. Sleeves would have been cheaper, quicker, and proven. In a small engine such as this, the weight savings is not even a factor.
Did someone feed you this line of BS or did you just make it up?
It's called innovation.
http://en.wikipedia.org/wiki/Innovation
PTWA provides a lower cost and lower weight alternative to cast iron liners, while delivering increased displacement in the same size engine package, and a potential for better heat transfer."
Feel free to prove me wrong. :)
