karl
Hans was developed to prevent basilar skull fracture, or your head disconnecting from your neck. http://en.wikipedia.org/wiki/HANS_device Some facts about helmets
You can register using your Google, Facebook, or Twitter account, just click here.I've heard Paul talk about how wearing a helmet in the Elio would be unsafe but after a number of searches I haven't found any studies to substantiate this claim. Is this just gut feel and marketing or is there actually some studies that can support this?
I'm a proponent of helmets on bikes (powered and non-powered) but I also support people's right to choose if they want to wear one or not.
In cars, and the elio, I'm like most people and really don't want to wear a helmet. However, given that your head is the most vulnerable part of your body head injuries in automobile crashes are often serious if not deadly. While searching for studies to support Paul's assertions I found many studies that discuss head injuries in crashes although only a few went so far as suggesting helmet use in cars.
As many motorcyclists are aware, we are inundated by "helpful" people that want to legislate our safety through helmet laws. When you look at the arguments for and against helmet use on motorcycles many of the same arguments can be made when applied to automobiles. So is the reason we don't have helmet laws for cars simply because there are more people that refuse to use them? Is it because people think cars are safer because they are surrounded by metal and other safety devices that will protect them?
Since I can't find definitive studies one way or the other I am left wondering if today's motorists are simply looking at the use of helmets in cars in much the same way motorists fought back against the use of safety belts. Ignorance, inconvenience, rebellion?
Ok, sorry for rambling but please, if anyone can provide a reference to support Paul's claim that wearing a helmet in the elio (aka a car) would actually be more dangerous than not wearing one I'd love to see it.
One thing I haven't seen mentioned directly (may have been in a link) is that Snell rates helmets differently for cars and bikes. The Snell "M" rating is for motorcycle use, whereas the Snell "SA" (Special Applications) helmet is rated for Auto Racing use. The main issue between the ratings is that the SA helmets are rated for MULTIPLE impacts (bounced around inside a roll cage) as opposed to a single major impact (the initial whack on the ground or other contact surface) that is expected with a bike helmet. Having owned both types years ago when I raced in SCCA's F440 class and rode bikes as my DD, there is a major difference in weight (the SA helmets being quite a bit heavier) and neck strain while wearing them.
With the airbag system planned for the Elio, I see no need to worry about a helmet inside it. The safety harness and planned airbags should do a great job of handling the unfortunate decellaration forces in an accident without injury to the driver.
I thought Snell also included requirements that the helmet be resistant to fuel as well. I wasn't aware that there was a M and a SA rating. I know the DOT requirements are not as strict as Snell requirements.
---- Snip! ----
The original question that was asked was to see if anybody could site a reference to support Paul's assertion that wearing a helmet in the elio would be more dangerous than not. There was one post that indicated some tangential information but thus far I have seen nothing to confirm Paul's assertion. Can anyone site some real research?
There is a flammability aspect to the SA rating, if that is what you mean by fuel. There are actually three different Snell ratings (see below), but I have personal experience only with the two I mentioned.
The only reason that I can see a helmet being more dangerous than not inside of a vehicle is if that helmet were not designed for use inside of one. At one point in time, Bell or Simpson had a very good case on helmet design for in-car use vs. bike use posted. If you want current info, perhaps a visit to Snell's site and the perusal of the standards and testing procedures would answer your question satisfactorily.
Snell Standards 2015 and prior
Snell Article & Document Archive
Below is a taste of the information to be found there. I can't go through it all right now to find information that will answer your specific question since I need to prepare material for my class tomorrow, but I think you might be able to find what you are looking for on their site.
Snell Standards specific question
What are the differences between the SA, M and K standards?
The SA standard was designed for competitive auto racing while the M standard was for motorcycling and other motorsports. The K standard was released to accommodate helmets used in karting. There are three major differences between them:
How do helmets work?
- The SA standard requires flammability test while the M and K standards do not.
- The SA and K standards allow for a narrower visual field than the M standard (Some SA and K certified helmets may not be street legal).
- The SA and K standards include a rollbar multi-impact test while the M standard does not.
Helmets are normally comprised of four elements; a rigid outer shell, a crushable liner, chin straps or a retaining system, and fit or comfort padding. The rigid outer shell, when present, adds a load-spreading capability, and prevents objects from penetrating the helmet. The liner, usually made of EPS (expanded polystyrene) or similar types of materials, absorbs the energy of an impact by crushing. The chin strap when properly buckled and adjusted along with the fit padding helps the helmet remain in position during a crash.
Helmets work like a brake or shock absorber. During a fall or crash, a head is traveling at a certain speed. Since the head has weight and is moving, there is a certain amount of energy associated with the moving head. When the helmet along with the accompanying head impacts an unyielding object, a rock, a wall, a curb or the ground, the hard shell starts by taking the energy generated by the falling helmet (head) and spreads it over a larger portion of the helmet, specifically, the internal foam liner. The foam liner then starts to crush and break which uses up a lot of the energy, keeping it from reaching the head inside. Depending on how fast the head is traveling, and how big, heavy and immovable the object is, the faster the head slows down, and the more energy is present. In short, everything slows down really quickly. A helmet will effectively reduce the speed of the head by breaking and crushing which reduces the amount of energy transferred to the brain. The whole process take only milliseconds to turn a potentially lethal blow into a survivable one.
