The tricky part about a spellchecker is you have to go back and check to see if the correctly spelled word was the word you actually wanted to use. I assume "sunroom" should have been "sunroof ".
You can register using your Google, Facebook, or Twitter account, just click here.Maybe with all the money that will be saved on his/her Elio, they can add a sunroom to their house.The tricky part about a spellchecker is you have to go back and check to see if the correctly spelled word was the word you actually wanted to use. I assume "sunroom" should have been "sunroof ".
BLANKETY-BLANK autocorrectSunroom???? What's a sunroom? I thought they were screened in porches on houses.![]()
Ok, we'll let that one slideBLANKETY-BLANK autocorrect
Putting a sunroof in the Elio was never a problem, but the issue was that it's going to be so small it's going to be more like a sun porthole in the roof. Because of the structure around the perimeter of the roof and the framework of the sunroof you would only end up with a opening that's about 10" side to side, and maybe 12" front to rear because of the curvature of the roof line. You can get glass to seal with a slight curve in the glass, but to match the roof line it will almost be like a small bubble. It comes down to, is it really worth it?A few weeks ago EM stated that they 'expected' to have the 20 +/- week P5 build complete in October with time for testing prior to the November LA Auto Show reveal.I asked whether they'll have time to do any testing with P5 before the show and got the impression that hadn't even been considered. My guess is that it'll be ready just in time for LA.
