Gas-Powered Awesome
Random amateur observations:
So, truly lovely to see progress, but this really is the "P6" production prototype to get the final dimensions and parts right. The "E2" will be the actual "E1", I think.
- Nice big engine mounts. Going to need them in a 3-banger without a balance shaft.
- Hood hinge arms and mounts suggest two, 2-armed, articulated hinges far simpler than complicated P5 sliding arrangement.
- Rear hub is... odd. Why didn't they use an off-the-shelf hub with internal ABS reluctor? Why the Rube-Goldberg contraption? Hubs like this can handle 2000 lb, have internal sealed ABS sensors, and cost $75 retail for one:
: - Rear swing-arm otherwise looks well done.
- Still adjustable coil-overs all around, so they are still fiddling with final ride height and strut length. Too be expected. We'll know it's really "production ready" when we see non-adjustable struts installed.
- Front plastic fender now has proper mounting flanges, unlike the P5. Good to see.
- Front strut-to-A-arm pushrod still adjustable with Heim joints. Again, that should go away and be replaced by fixed-length rod with proper sealed joints when it's "production ready".
- I seen an air bag in the A pillar.
- Gauges are conventional!
- Elio looks good in white.
