Marshall
I lived in Michigan long enough to know you can ONLY turn right.Assuming they are all in the same direction! You know what assuming does>
You can register using your Google, Facebook, or Twitter account, just click here.I lived in Michigan long enough to know you can ONLY turn right.Assuming they are all in the same direction! You know what assuming does>
Since a powered subwoofer is one of the options, I would have to say yes.Does anyone know if the proposed MTX head unit will have pre-amp outs (and a remote power out) to connect a mono amp and eventual subwoofer? All you need then is power to the amp (with its own fuse) and we should be set.
Will the Elio come with a basic radio or is it one of those things WE get to decide to add or NOT? I can live without it myself.Since a powered subwoofer is one of the options, I would have to say yes.
The one they are offering is made specifically for the Elio; it's designed (acoustically and physically) to fit back in the trunk area, and still leave you some room back there.
AM/FM Radio is standard.
https://www.elioowners.com/threads/the-turbo-elio-is-coming.6247/If I could put a turbo on it, it wouldn't need a radio.
I've heard a 78/21 percent mixture of pure nitrogen and pure oxygen will keep your tires inflated, too. Don't know about the other 1 percent. I guess you could just mix in some air to make it 100 percent.
