You can always ADD this Can-Am OPTION:
Good link. I'm all in on these lights if EM doesn't offer them as an option. In fact Can-Am would be smart to customize them for the Elio fender when the time comes.
This is an aftermarket item so Can-AM does not make it directly which is good for us as I am sure this company would be interested in more potential customers: http://www.customdynamics.com/dual_color_magicflex_channelz.htm
The Can-Am Spyder does come from the factory with a basic fender lighting package so this kind of option is easy to add to a Spyder. The Elio will not likely come from the factory with fender lighting so I hope EM makes it relatively easy to add some. Either way the aftermarket will come up with solutions. It really should not be very difficult to splice into the turn signal/running light wires to enable this functionality and depending on how everything is laid out it may be possible to create some pass through connectors for the front headlight/turn signal assembly allowing for a nice plug and play wiring solution for running and signal light functions.
