UCF'73
Well I can get the LEDs, and some wire, and I can drill holes. Then do you run the wire and patch onto the headlight connection or what? You have to draw the juice from somewhere after the on-off switch. I'm sure I can figure it out or get help when the time comes. EM probably ought to just go ahead and wire it up. It would cost next to nothing and might avoid having to recall a couple hundred thousand units after a few of those invisible wide-track fenders get whacked on dark narrow roads.Little LEDs. Amber on the front, red on the back. All it takes is a 1/4 inch hole and some tiny wire.
