A year ago I helped a friend put in a 220V charger in his garage. What made it really easy was that the panel box was in the garage and there was no drywall on that wall (running the wires was really easy). His house has a 300A service because originally it was all electric. He had a new HVAC system put in and went with oil heat boiler system thus it opened up some space in the box and overall amp load. We actually used the same 80A circuit that used to run the heat strips in the heat pump (it even had an open 60A for the old electric hot water heater). He bought whatever wall charger that would work for 80A. So, his level 2 charger works quite well.
He has a BMW i3 with the range extender. He bought it used for $14K and it only had 20K on it. he does a 80 mile round trip for work. best part is, at work there's a 110 outlet by the corner of the building and they let him charge it there during the day. It's back up to 100% after he's been at work for an 8 hr shift. At home it takes 3 hours if the battery is almost dead. Over the past year he's put over 20K miles on it and his bill for oil and electric for the house (along with charging the i3) is down 20% from when it was all electric just a year ago. The i3 has used 2 gallons of gas in a year.
I make fun of him because he converted his house to diesel and his car to electric. I told him that he should have bought a BMW diesel and then use the home heating oil in it (as it's not taxed).
